Tach/Dizzy
gotgohan
Which wire would I be able to put directly to tach from distributor, is there anything but that blue wire
integra tach signal
obd0= blue at dizzy
obd1= blue at dizzy
obd2a =blue at dizzy OR
* Distributor Located On Passenger Side Of Engine. Tach Test Connector Is a 2 Pin GRAY Connector Located On Driver Rear Of Engine On Strut Tower. Tach Wire Also Located In 16 Pin GRAY Connector Above Fuse Block Behind Driver Dash (LS & GS-R Models) Or 14 Pin Connector Above Fuse Block (RS Models).
obd2b= blue at dizzy
Theres no wire before that? because I am getting a signal from the blue wire on the 2 wire grey connector and I have two clusters and neither tach work.. that can't be coincidence. Is there a wire that is directly hooked to the distributor
Thats the thing I am getting a negative feed at the cluster... I have another cluster too that i've tested and still nothing sigh.
