ok so i have a 89 civic hatch dx, and i swaped in a zc... but anywayz i just bought a tach and i got the ground hooked up and the power... but when i hooked up the green rpm wire to the blue rpm wire inside the dizzy and turn on the car and nothing happend... any ideas?
im not sure on that one i just tapped my into the blue wire on the dizzy hook up to the postive and negitive and found a wire in the dash that lites up something for the illumination.
aight now i have a new problem, the light turns on on the tach, but its not bright at all... i cant see the tach for shit at night time, is there a way to fix this?
did you try moving the dimmer switch to make it more bright or less bright try that once. cuz i hooked mine up to the rear defrost wire that lights that switch up and my tach is bright as all hell.
i tryed that alredy and it dosnt dim the tach or make it brighter, it just stays the same... so i gess ima try and hook it to the rear defrosters, but what wire did you hook it to?
