tach wire
Discussion in 'Prelude' started by bigdaddy, Apr 12, 2009.
  1. bigdaddy
    bigdaddy New Member
    Does anyone know what wire I need to use to hook up a aftermarket tach in a 92 prelude with a 96 h-22 jdm motor thanks
  2. Stleger184634
    Stleger184634 New Member
    Maine
    there is a green wire that comes from you distributor and goes through ur fire wall to your gauges that is the wire easiest way to find it is to take ur guages out and look behind the tach then snip it and you can either put a junction if you want to keep ur old tach working and put in a shift light or you can jsut solder it up to the aftermarket tach wire and ur good to go
  3. DESPAIN
    flower mound TX
    Its alot easier if you just tap into the plug on your dizzy. There is a two wire plug on wire is blue the other is y/g i think but the blue one is the best to tap into.
