Tachometer Does Not Work!
Discussion in 'ECU's, Electronics, and Tuning' started by RFHOMI2U, Jan 27, 2003.
  1. RFHOMI2U
    RFHOMI2U Senior Member
    The Tachometer in my 2nd gen CRX Si does not work! i'm pretty sure it was working before i finished my swap, but it does not work anymore. I posted something about this earlier, but i did not get a straight answere. How does this hook-up??
  2. slammedb18acivic
    slammedb18acivic Senior Member
    pa
    whats up, is it only your tac that doesnt wrk if so check the blue wire on the distributor , and your speed sensor not to mention all fuses
  3. RFHOMI2U
    Would the speedometer actually have anything to do with it?? because the speedometer doesn't work. Would that have anything to do with it?
