taking pully off of b series
Discussion in 'Engine Building' started by qtmac_mien, Jan 19, 2005.
  1. qtmac_mien
    qtmac_mien Senior Member
    is there a easy way to take off a b series pully while the motor is in the car?? i noe one easy way is to use a air gun, but i dont have one and the whole motor is already in the car. any ideas?
  2. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    i am having the same problem i think mine is over tq'ed if you have the right tool i forgot what it is called but it fits right into the crank and you put a 19mm socket in there and turn counter clockwise and you are good to go!
  3. qtmac_mien
    do you noe where i can buy that special tool?
  4. adaml2nv
    adaml2nv Member
    it's a chain wrench. you can get it any auto store. autozone,checker, etc.
  5. BodyDroppedNikes
    caught in a mosh...
    the crank pulley removal tool? only place you can get that from is from your local Honda dealership. i was quoted like $100 for it if i remember correctly.
  6. civiclxb16
    Poconos pa
    i payed 64 from snap-on
  7. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    its called put the car in gear and have a friend hold the brakes then get a good sized breaker bar
  8. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    have someone hold the flywheel with a pry bar, then break the pulley nut loose
  9. hcivic.com
    bad idea i ahve seen teeth break off
  10. civiclxb16
    Poconos pa
    just buy the tool so that way if you ever need to change the timing belt water pump and so on you have the tool and you can even do the timing belts for your buddys and make some money and call it a day i do it all the time now that i got that tool and a impact wrench
  11. B16RacerN2NR
    Moving back West...
    sucks to be you, i've done it hundreds of times, of course now i have air tools
  12. 97CTR
    97CTR Senior Member
    moroso makes a tool as well moroso
    you will use it more than once
  13. driverunknown
    driverunknown Senior Member
  14. civiclxb16
    Poconos pa
    holy shit i wish i would know amzon sold tool i would of bought that one save me almost 50 bucks but what is done is done
  15. qtmac_mien
