TB with FITV
Discussion in 'HYBRID -> EG-EK / DC' started by custompainter, Mar 12, 2008.
  1. custompainter
    custompainter drive it like U stole it
    central CT
    whats the difference between a throttle body with a FITV and with out ??
  2. eg6sir
    2 separate pieces basically..
  3. custompainter
    central CT
    yeah but what does the FITV do whats it's purpose
  4. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    You know when you start a car and its cold outside and it wants to die until it warms up....? It keeps the car from dying until it reaches operating temperature.
  5. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    Not dying....
    The FITV is a plunger with a wax mechanism. When the coolant from the engine running through it is cold, the plunger is keeping a bypass open to allow more air past the throttle plate, thus raising the idle to decrease the warm up time durring idle and get the much needed oil temperature up. Once the coolant gets up to temperature, the wax expands and the plunger closes, reducing the bypass air to only the air getting past the throttle adjustment screw and the IACV (if equiped).
    You can run an aftermarket throttle body lacking the FITV with no issue. In the same respect, you can also run a throttle body with a detachable FITV by putting a blockoff plate over the hole to prevent the extra air from always getting in. It has no electronics, and cannot throw a code.
  6. custompainter
    central CT
