I'm having a problem I could use some help with. I finally finished my ls/vtec build and now I'm just working out some bugs.
My build is a 96 teg with I believe a 99 si head (I don't know how to identify what year the head is, but I know it's an OBD2). Also I did a obd1 ecu conversion which eliminated alot of problem from the stock GSR ecu I was running but now I'm getting a TDC code and my speed/tack doesn't work. I'm hoping there is a simple solution but I need some guidance.
Thanks
Thanks
