crxhfz6
i have an obd1 crx that was throwing a code for the TDC and CYP. a couple days ago i was givin a lightly used distributor(5k miles). i ended up putting the coil and control module from mine into the new one. started right up and didnt throw a code. went for a drive and went well until i hit around 6k. then the tach went crazy and i got a code for the TDC. i turned the car off then back on and it went away and drove fine. I believe all of the wiring is good. would it make sense for the sensor to be bad, or is there a problem in the wirin?
