Techna-Fit SS Brake Lines
Discussion in 'CorSport' started by CorSport, May 14, 2010.
  1. CorSport
    CorSport Member
    Corsport is now offering Techna-Fit Stainless Steel Brake Lines for a large majority of applications!
    All Categories
    All of Techna-Fit's assemblies are assembled in-house, meeting D.O.T. Certification. Techna-Fit brake line kits come complete with all of the fittings and bolts for easy assembly.
    One advantage is that Techna-Fit lines reduce volumetric expansion. Over time and under continuous use, OEM rubber lines can swell and expand, exposing the driver to brake fade. The rubber cover is also vulnerable to attacks from the ozone layer (rubber deteriorates and causes failure). In extreme applications (auto x, racing, hard driving) rubber hoses might be susceptible to debris, thus causing failure. Stainless steel hoses provide some added protection from these issues.
    At Corsport, Shipping is always free to the lower 48 states.
  2. TurboMirage
    got these on my racecar. fitment is great and pedal response is nice.
  3. CorSport
    CorSport Member
    ^ Sweet, glad you like em!
  4. TurboMirage
    yes, they match up nicely with the 2 piston evo/gsx fronts, gvr4 rears, and 3kgt abs MC :)
  5. CorSport
    CorSport Member
    We're glad to hear it!
  6. CorSport
    CorSport Member
  7. CorSport
    CorSport Member
  8. CorSport
    CorSport Member
  9. CorSport
    CorSport Member
    Improve clutch and brake pedal feel!
  10. CorSport
    CorSport Member
    SS clutch lines and brake lines!
  11. CorSport
    CorSport Member
    "All of Techna-Fit's assemblies are assembled in-house, meeting D.O.T. Certification. Techna-Fit brake line kits come complete with all of the fittings and bolts for easy assembly. "
  12. CorSport
    CorSport Member
  13. CorSport
    CorSport Member
  14. CorSport
    CorSport Member
  15. CorSport
    CorSport Member
    Brake AND clutch lines.
  16. GSRCRXsi
    MD
    hard to tell. are these covered by a plastic or rubber like coating over the SS line? to prevent dirt from getting in the SS braids?
  17. lostsoulzprophet
    lostsoulzprophet delslow
    georgia
    ive got a 93 del sol si.<< rear disc brake how much for all around brake lines
  18. CorSport
    CorSport Member
    Yes, they have a rubber/plastic barrier on them to protect from corrosion etc.
    Lostsoulz, checking now. We've got em up for an EG but i'll check on the del sol.
  19. lostsoulzprophet
    georgia
  20. CorSport
    CorSport Member
    We should be able to get the front and rear for the same price as the EG. IF you're interested let me know.
