'TEG swap q's
Discussion in 'HYBRID -> EG-EK / DC' started by Smonkeyboy, Oct 21, 2002.
  1. Smonkeyboy
    Smonkeyboy Senior Member
    Spokane, WA
    i just got a 1990 teg RS and was ondering first of all what the code was i couldnt find it on the block B18??
    what are EASY, CHEAP swaps
    ne help would be great :worthy:
  2. pissedoffsol
    DONT swap it.
    its a b18a.
    boost it y0
  3. knowledge
    knowledge Senior Member
    Beale AFB, CA
    W3RD B! Boost that shizzy yo!
  4. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    If you have the slightest desire to boost, just build the LS block for it. If you know that you do not want to boost, don't swap, LSVTEC.
  5. Smonkeyboy
    Spokane, WA
    it has 141K
    if i wanted to boost i would either have to remanufacter
    or get it cracked and pressure tested (ass expensive)
    i was thinking B20 all motor, polished, pistons, rods 12.5:1
  6. phunky.buddha
    Dallas / Fort Worth, TX
    The B20's just going to choke with the stock head on it NA... if you're going to go all motor with a B20, drop a VTEC head on it.
  7. lsvtec
    If you want to LSVTEC with the kind of mileage you would have to remanufacture anyway. The LSVTEC (IMO) is going to be your most cost effective way NA in that car because you already have the LS bottom end.
  8. [Jett]-CRX
    [Jett]-CRX Member
    Maumelle, AR
    Yep... if you already have the LS block, you can have Golden Eagle Mfg resleeve it and bore it to 84mm (2.0l, just like the B20) for about the same as the cost of a B20 block.
    http://www.goldeneaglemfg.com/sleeves.htm
    Email Vince and he can tell you all about it. Once you get your block back, you'll be able to boost the crap out of it with no worries.
    There was a cool writeup about Golden Eagle's process here:
    http://www.overboost.com/story.asp?id=464
  9. phunky.buddha
    Yup. I'm still considering boost... just farther on down the line.
  10. Smonkeyboy
    Spokane, WA
    further down the line im thinking
    S14 240sx :worthy:
    SR20DET :worthy:
    JDM lights :worthy:
    the teg just needs to lay down low 14's for now
    what about nnaaawwwwwzzzz????
