Tein Install
Discussion in 'Wheels / Suspension / Tires / Brakes' started by SpyOneUSN, Mar 31, 2003.
  1. SpyOneUSN
    SpyOneUSN Senior Member
    if im puttin in tein flex in my ride(98 ex coupe), do i needa get a spring compressor? the whole assemblys comin out so do i still need to compress it? also, any pointers about the install would be greatly appreciated. also, are traction bars esy to install? are they worth it and are they good for daily street use?
  2. B16
    B16 Super Moderator VIP
    yay area, CA
    if you are re-using your stock upper mounts, then yes you'll need a compressor to get the mounts off. however, because of the height adjustability, you do not need a spring compressor to reassemble. install is pretty straight forward.
  3. SpyOneUSN
    not sure but i think the flex's come wit replacement upper mounts. just got approved for a $1500 credit card today :D
    by the way, how much did your swap set you back?
