Tein Now Available At CorSport
Discussion in 'CorSport' started by CorSport, Oct 20, 2011.
  1. CorSport
    CorSport Member
    96-00 Honda Civic Tein Street Basis Damper Kit
    [​IMG][​IMG][​IMG]
    Click here to see this product in our catalog and check out the most current pricing.
    Tein Street Basis Dampers -*Ride Height adjustable
    The Street Basis damper is the evolution of the popular BASIC coilover. Developed to provide a sporty ride feeling and aggressive stance. The shortened shell case design provides optimum damper stroke at lower than standard vehicle ride height. Vehicle ride height is adjustable via the ZT coated threaded sleeve. Updated internal components and external coatings increase durability and product life. Street Basis dampers are great for daily driving and spirited driving for all types of drivers.
    Made in Japan under strict quality control standards and developed by highly trained suspension engineers.
    Additional Features
    • Steel Construction
    • Twin Tube internal construction
    • Larger piston diameter for strut type front and rear (22mm)
    • Ride Height adjustable via spring seat
    • Powder coated damper body
    • Non-welded ZT coated Adjustment Tube
    • Full-Length Dust Boots
    • 1-piece Aluminum Spring Seat with Delrin Thrust Washer
    • Available for Overhaul
    • 1-year Manufacturers Defect Warranty
    Contents of Damper Kit:
    Shock Absorber × 4 Bump Rubber × 4
    Main Spring × 4 Hook Spanner × 2
    Some applications include helper springs Dust Cover × 4*
    Spring Seat × 4 *Some kits will retain use of OEM Dust Covers
    Seat Lock × 4 Instruction Manual × 1
    Delrin Thrust Washer × 4 Sticker Sheet × 1
    Ride Height Adj Range (R): -1.1~-2.3in (-28~-58mm)
    Ride Height Adj Range (F): -1.0~-2.2in (-25~-56mm)
    Spring Rate (R): 224lbs/in (4kgf/mm)
    Spring Rate (F): 448lbs/in (8kgf/mm)
    Uppermount: OEM Uppermount
    If you have any questions you can reply to this thread, send us a pm or use the contact us page on our website.
    Thanks for the continued support,
    CorSport USA.
  2. CorSport
    CorSport Member
    Huge selection of everything Tein available at CorSport.
    CorSport: Tein
  3. CorSport
    CorSport Member
    Anything and everything Tein available at CorSport!
  4. cjvictoria
    cjvictoria New Member
    N. Chuck, SC
    Is there a CRV application? I was just wondering because I may buy one soon...
  5. phunky.buddha
    Dallas / Fort Worth, TX
    1G CRV suspension is like an EK. 94-97 Accord springs work well with the heavier chassis.
    :D
  6. cjvictoria
    N. Chuck, SC
  7. CorSport
    CorSport Member
  8. CorSport
    CorSport Member
    Tein in stock and ready to ship!
  9. CorSport
    CorSport Member
    92-95 Honda Civic Tein S.Tech Springs
    [​IMG][​IMG][​IMG]
    Tein*Stylish Spec Dress Up Master S.Tech Springs
    TEIN S.Tech Springs are an excellent step towards suspension tuning. They offer approximately a 1.5 inch drop for a more aggressive appearance and increased road holding capability. Designed to be used with OEM or OEM replacement shocks. Each application is road tested in North America for the proper balance between performance and comfort. Comes with a 1 year limited warranty, spring length is guaranteed not to sag more than 5mm, and be clear of any manufacturer defects.
    Additional Features
    • Chrome Vanadium SAE9254V Construction
    • Progressive Spring Rate Design
    • Includes Silencer Rubber on certain applications
    • Green Powder Coat Finish
    • Developed to be used in conjunction with OEM or OEM replacement dampers
    • 1-year Manufacturers Defect and Sag Warranty
    Covers over 5mm sag, breakage, deformity, and noise.
    Does not cover powder coat finish and rusting.
    Individual Springs × 4
    Main Spring × 4
    Some applications include TEIN Silencer Rubbers
    Warranty Information and Bump Stop Reference Guide
    2 TEIN Decals *
    Ride Height (F) -1.81in (-46mm)
    Ride Height (R) -1.73in (-44mm)
    Spring Rate (F) 210lbs/in (3.8kgf/mm)
    Spring Rate (R) 140lbs/in (2.5kgf/mm)
    CorSport USA.
  10. CorSport
    CorSport Member
  11. CorSport
    CorSport Member
    94-01 Acura Integra Type-R Tein Flex Damper Kit
    [​IMG][​IMG][​IMG]
    Tein Control Master Type Flex Street/Track Damper Kit
    TEIN has used its years of experience in various motor sports to produce a kit that provides the ultimate balance between comfort and performance. Developed for drivers seeking an aggressive coilover that can be used daily, and provide all the adjustments needed for circuit use. The FLEX damper Kit features the latest technology for all drivers who are seeking performance, and adjustability, while not giving up all ride comfort. We have incorporated separate spring perch height, and shell case length adjustment, which allows the suspension to retain more stroke and allows for more suspension tuning. The FLEX damper kit includes pillow ball upper mounts, which increase steering response; 16 levels of damping force adjustment, and is compatible with the EDFC (Electronic Damping Force Controller) for added convenience and adjustability.
    Additional Features
    • Ride Height adjustable via threaded body and spring seats
    • 16 way adjustable dampers, compression and rebound combined
    • Pillow ball upper mounts for increased steering feel
    • Upper camber adjustment on front for strut type vehicles
    • EDFC (Electronic Damping Force Controller) compatible
    • Powder coated brackets with Teflon coated shock body for heavy duty rust prevention
    Adjustable Shock Absorber × 4 Bump Rubber × 4
    Pillow ball Upper Mount × 4 Instruction Manual × 1
    Lower Spring Seat × 4 Sticker Sheet ×x 1
    Seat Lock × 12
    Upper Mount*w/ Camber Adj
    Damping Force*Adj.
    Full*Length Adj.
    EDFC Comp
    Twin Tube*Design
    Ride Height Range (F)*0 / 0 to -80.0 / -3.15
    Ride Height Range (R)*-18.0 / -0.71 to -81.0 / -3.19
    Spring Rate (F) 560lbs/in (10kgf/mm)
    Spring Rate (R) 390lbs/in (7kgf/mm)
    CorSport USA.
  12. CorSport
    CorSport Member
    94-01 Acura Integra Tein Street Basis Damper Kit
    [​IMG][​IMG][​IMG]
    Additional Features
    Spring Rate (R): 340lbs/in (6kgf/mm)
    Spring Rate (F): 450lbs/in (8kgf/mm)
    CorSport USA.
  13. CorSport
    CorSport Member
