Tell me about chipping ECU's
Discussion in 'ECU's, Electronics, and Tuning' started by austinkli, Sep 13, 2009.
  1. austinkli
    austinkli The Blackberry Dude
    Jacksonville, Fl
    O Hai Guise! Let's discuss chipping my ECU.
    I am not overly familiar with all of this. What are the advantages of chipping my ECU. Currently I have a P08 running my D15B motor. How does chipping my ECU help me? What can it do?
    I'm talking about keeping the motor stock other than an i/h/e.
    Don't "lmgtfy" because I don't want google. I want personal opinions and ideas from you guys. And better explanations on how it actually works.
  2. austinkli
    Jacksonville, Fl
    Oh btw, sorry I didn't specify, it's a D15B w/vtec
  3. 94civicturbo
    94civicturbo New Member
    Liberty, IN
    well if you do chip it go with Hondata, this is a list of the features off their website:
    Fits inside the ECU
    Made in USA
    Built on the proven s100/s200 code base
    USB connection for speed and compatibility
    SManager Windows based software for parameter & table editing, calibration uploading and datalogging.
    Real-time updating of ECU
    Built in calibrations for common engine combinations
    Built in datalogging to a laptop
    On board datalogging memory (2 MB memory, 20-60 minutes datalogging)
    Adjustment for different sized injectors, with overall fuel trim.
    Configurable for any MAP sensor (to at 5 Bar and above)
    TPS based table lookup for ITBs
    Engine protection from over boost.
    Expanded fuel and ignition tables, both in rpm and load, to 60 lbs boost and 11,000 rpm (these are not the upper limits)
    Launch control with anti-lag
    Full throttle shift
    Three multi purpose outputs for nitrous control or similar
    Supports lambda tracing from a wideband o2 (PLX wideband recommended)
    PWM output for boost control
    Dual tables for high/low octane calibrations etc.
    Two analog inputs for wideband, EGTs etc.
    High and low speed 24 x 20 ignition and fuel tables for correct VTEC tuning
    Injector size fuel trim
    Fuel trim for starting, throttle tip in and individual cylinder trim
    Rev limiter with fuel cut or fuel and ignition cut
    Full throttle shift
    Adjustable VTEC window with load and throttle control
    Secondary intake runner control
    Adjustable idle speed
    MAP sensor type and calibration
    Adjustable boost cut with hot and cold settings
    Shift light
    Closed loop control
    Air temperature compensation
    Water temperature compensation
    Fuel and ignition correction based on gear
    A/C shutoff conditions
    Closed loop
    Three general purpose outputs for nitrous control, quad boost control or similar
    On board datalogging trigger conditions
    hope that helps you some...
  4. austinkli
    Jacksonville, Fl
    Well aren't you just Mr. Helpful today. But I'm afraid I wasn't real clear on what I was asking. I'm kind of curious as to how it works when you chip it. Does my ECU suddenly know to tell the car to use more fuel? Does it understand that I have an intake on and tell it to take in more air? Stuff like that.
    Keep it in lamen's terms for me if you will.
  5. GlassHeadlights
    Calgary, AB
    If the motor is stock there wouldn't be any advantage with tuning.
  6. INJEN78
    INJEN78 HS LEGEND
    OHIO
    dont have to necessarily go with hondata..its really not all its cracked up to be..
    you should chip your ecu because p08 doesnt run vtec..
    but basically when you chip and ecu it gives you the ability to adjust fuel and timing maps..also vtec engagement point,rev limiter,all that good stuff..
  7. 94civicturbo
    Liberty, IN
    well the person that tunes your car will adjust all that stuff to what you have done to the engine, so if you have more plans for it just wait on the chip and if not then go right ahead and get it chipped and tuned lol
  8. disableddan
    disableddan Crazy Insane
    Edmonton Canada, Eh?
    Not entirely sure this is true, the factory fuel and spark maps are tuned for reliable economy, not maximum horsepower. With i/h/e and some other goodies you could probably tune a little more power out of it too.
    Not that I really know that much about this stuff either :D
    I'm still trying to learn more about the intricacies of chipping and tuning... lots to learn :p
  9. 94civicturbo
    Liberty, IN
    ^^^ yeah me too so im trying to be helpful without looking like an idiot...
  10. GlassHeadlights
    Calgary, AB
    P06 doesn't run VTEC. P08 is the JDM D15B ECU.
  11. INJEN78
    INJEN78 HS LEGEND
    OHIO
    damn i had them mixed up...hes correct
  12. austinkli
    Jacksonville, Fl
    Umm.... Yes it does.
  13. austinkli
    Jacksonville, Fl
    And upon further reading I realize that you guys already established that.
    Basically what I'm thinking overall, is to do a full i/h/e on it. A few minor minor things like higher combustion NGK spark plugs, wires, etc, then getting the ecu chipped for the maximum hp out of it rather than the best gas mileage.
    this car/motor is never going to be anything special, just a daily drive that I'd like to be just a little peppy.
  14. INJEN78
    INJEN78 HS LEGEND
    OHIO
    lol yea..
    well you can def. tune a couple more hp out of a couple boltons and a tune..
  15. chacal06
    chacal06 New Member
    los angeles CA
    So there's is other ways to adjust how much fuel it uses other then chipping it ?
  16. INJEN78
    INJEN78 HS LEGEND
    OHIO
    a vafc or safc..or another piggyback managemant system
  17. jajimenez
    jajimenez New Member
    EL Paso
    I adjusted everything with a small tuner, you should have no problem.
  18. disableddan
    Somewhat unrelated, but I have an issue of "Grassroots Motorsports" (great mag btw) where they put megasquirt on an old rx7 motor. With only tuning they were able to get an extra 20hp and 25 ft lbs, AND improved fuel economy to boot :p Not sure if rotaries take to tuning better (or if they just had a shit tune from the factory) but there's definitely room for improvement through tuning, even on a stock engine.
  19. riceracerex
    riceracerex D-Series Ninja
    Pryor, Ok
    I just chipped my PM6 Ecu in my Crx. "D16a6". About your question... IMO Chipping is one of the best things you can do to a car and it is very good to learn as long as you read alot and ask lots of questions. INJEN helped me out some when I was first setting mine up.
    The Advantages of chipping like INJEN said, is Adjusting Fuel & Ignition timing based on RPM's and Intake Manifold Pressure. It sounds complicated but it's not. You can download basemaps * custom programs to run your car and ecu * I/H/E should help with the InHg (Intake Manifold Pressure) You will have the option to perform a 2-Step (Lauch Control)
    Adjust when your Vtec Engages and alot more... I am very happy with my chip and I only have a few mods like I/H/E & Adjustable Cam Gear. You can also Log Information from the Sensors in your car with a DataCable running it to a laptop. This will help you determine if you are running to much gas or not enough. Rich or Lean. A Wideband O2 Sensor helps with this.
    If you have any questions about it reply and I will see what I know. I would not ever recommend a Ebay chip though. Tuning it yourself is a great accomplishment and it's also alot of fun. Just make sure you are good at soldering or patient with it and your good to go. Hope this helps, if not you can always go to xenocron.com or pgmfi.org
    1 person likes this.
  20. INJEN78
    INJEN78 HS LEGEND
    OHIO
    exactly^ repped for refering to me and providing good info..
