tenzo r
if your strut stuck up through your inner fender, you forgot to put the washer on the strut rod below the upper strut mount.
i probably did just that then seeing how that was the first set of springs i ever did thanx back off come the springs
If you put it back together the way you took it apart you wouldn't have had the problem.. maybe you should pay someone to work on your car.
