Testing A Sitting Motor
Discussion in 'General Tech and Maintenance' started by GlassHeadlights, Dec 28, 2009.
  1. GlassHeadlights
    Calgary, AB
    I'm looking into a B18C1 GSR swap for $1000. It's too cheap for a swap so I want to compression test the motor maybe by bringing a battery and jumping the starter.
    The kid seems like a dink, when I first called him the motor was in the car then the next day he pulls it out. I said that sucks because I wanted to test it out and he said I promise it's good.
    He's sending me pictures, not that it tells me anything.
  2. RoughKnight
    RoughKnight Christmas Car
    Ottawa, Ont
    yaaaaaa
    take it from me, the next time I buy a motor, its:
    1) from HMO
    2) I'm watching him drive in it before he pulls it
    Don't "trust" because its a cheap price, my engine is living proof lol
  3. GlassHeadlights
    Calgary, AB
    Yeah, and there could be so much wrong with it. Trans could have shot syncros, dizzy could be done, it could be a smoker. Plus he said it haz teh type r ecu so you can revvv it to 9 grand yo.
  4. kelsodeez
    kelsodeez New Member
    bay area, CA
    i agree. its better to buy it from a place that stocks motors and gives a guarantee on start up so if it doesnt start, you just go and grab a different one.
  5. 93sedanVX
    93sedanVX New Member
    Toronto, Ont
    If it sounds too good to be true, it probably is. But even still, the entire swap for $1000? Even if it needs a re-build, thats not a bad deal.
  6. GlassHeadlights
    Calgary, AB
    I'm still going to check it out. I'll look at the plugs when I do a compression test.
    Anyone else have more ideas?
  7. phunky.buddha
    Dallas / Fort Worth, TX
    Bring a compressor and leak-down tester. No need to jump the starter, and it's a more comprehensive test.
  8. GlassHeadlights
    Calgary, AB
    It's just a spark plug adapter right? I can get that from work.
  9. phunky.buddha
    That and a few gauges- one that lets you read the line pressure and one that lets you read the cylinder pressure. You can usually buy a leakdown tester manifold with gauges on it for something like $40 in the right places.
  10. kelsodeez
    bay area, CA
    isnt the only thing you can check on a sitting motor is the compression? i was under the impression that you could turn the crank with a socket wrench and measure the psi to see if all cylinders are close to the same, and none of them leak any pressure out.
  11. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    :werd:
    Turning the crank by hand may be too slow and allow pressure to leak through camming. Though, if it holds pressure is should be fine(constantly hard to turn during a compression stroke). Also, you can hear a distinct exhaust cycle with the exhaust(or in this compressed air) coming out.
  12. RoughKnight
    Ottawa, Ont
    ^damnit
    you beat me too it
  13. eg'sforlife
    eg'sforlife New Member
    29 stumps, CA
    take two straws...stick em together then put them in the spark plug hole resting on the piston rotate the crank on each cylinder to tdc watching the straw move slowly till it hits the top..... then do you leak down test on that cylinder...thats how i do it
  14. GlassHeadlights
    Calgary, AB
    The motor is still in the car. THIS KID IS FUCKING WITH ME.
    So he first contacts me and says I need to get rid of this motor quick. It is still in the car but I'm pulling it out tomorrow. I call him the next day and he said he pulled it out. I said thats too bad because I wanted to test it. Today I came to his house and his dad was there, nice guy and all, and he says he hasn't pulled anything. He didn't have a key but my dads Honda key opened the door. I pop'd the hood and its there. Jasma header, Edlebrock intake manifold, S80 trans (ITR transmission) but the valve cover was leaking oil. The key wouldn't start it though.
    I guess his dad told him I was there and he texts me and said, quote off of my cell, Thats wierd, I thought you would have waited like I said, I wanted to be there. I said, well you wanted to get it gone quick so I was hopeing you would be there. Your dad showed us around and he seemed alright with it. Then I said I want to hear it run and do some tests. And it is $1000 right? He says well I have a guy on Friday who will take it for $1500 so $1250. I said no way, you said one grand two days ago. If it falls through give me a call.
    Hes pissed at be now because I saw it when he wasn't there. Fuck him.
  15. RoughKnight
    Ottawa, Ont
    wow ya
    btw if the valve cover is leaking oil, it sounds like he's one of those retards that watched dragon ball z growing up and can rev his car "over 9000."
    stay awayyyyyyyyyyyyy
  16. OGMatt
    OGMatt Not a real OG lol
    vic B.C. Japanada
    9k all day. This shits sour dude.
  17. GlassHeadlights
    Calgary, AB
    He texted me back and said you're worried about $250? The trans alone is worth $1000. Plus I'm still pissed at you because you came when I wasn't there. So $1250 or I have a guy on friday for $1500. I said againg if it falls through I'm here for a grand. He doesn't have another guy. He will phone me on Saturday. :)
  18. Ethan
    Ethan Well-Known Member
    2 bottles of nos in the back seat location?
  19. kelsodeez
    bay area, CA
    and a turbo with the wastegate welded shut.
  20. eg6sir
    thing is with that.... you usually need to have it professionally installed or else they dont warranty it... so that means you can drop the motor in yourself because they can say you did something wrong that messed it up
