Testing solenoid
EP3Hatch1987
Meeeeooowww!!!!!
Does anybody know how I would be able 2 test my vtec solenoid 2 see if it's working?
run a wire from it straight to the battery, just tap the wire to the hot post and see if its clicking
well it could be a few different things. are you throwing any check engine lights. ? and check your oil level
then it should be working if the code was fixed. what motor is it some sohc motors you cant hear or feel
Okay I might juss go buy a new oil switch.. And do you know the wiring diagram 2 wire in the vtec? Cause I had 2 wire mine in cause it's a dx model
as long as its to the right pin on the ecu it will be fine, search for the ecu pin out that your using
