Testing the TDC on a D17A1 01-04 Civic
Discussion in 'ECU's, Electronics, and Tuning' started by n1mr0d, Mar 9, 2011.
  1. n1mr0d
    n1mr0d Senior Member
    Channahon, IL
    Does anyone have the procedures for testing the TDC on a D17A1. I have a new one on order but I would rather test the old one then blindly replace it.
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    ? Not sure what you're talking about. TDC=Top dead center, the position of the crankshaft/piston. You can't really replace it.
  3. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    I'm confused too... How do you replace Top Dead Center?
  4. hondafreak513
    hondafreak513 New Member
    O hi O
    You gotta replace the whole internals of the distributor....
  5. n1mr0d
    Channahon, IL
    I'm sorry guys for not being more clear. When I said testing the TDC, I meant the TDC sensor, aka the Camshaft sensor. It senses the angle/rotation of the camshaft in realation to the the crank, sends the signal back to the ECM and allows the proper fuel management.
    The 01-05 Civics have direct coil ignition systems so it is not in the distributor. If I remember correctly, the 01 was the first year the Civics had distributor-less ignitions.
    But I found the procedures in a service manual.
