**testing waters** FS LSV, b16 trans FS **testing waters**
Discussion in 'Parts: For Sale/Trade/Wanted' started by formby, Feb 15, 2007.
  1. formby
    formby learning in progress
    long story short
    i dont want to spend more money on anything to make my 300-350 hp goal. and i know that my d series will make it there if i build it right.
    So i'm selling the LSV with tranny as a swap
    ENGINE IS INTACT WITH TRANNY ATTACHED
    parts list
    this engine was run in an OBD0 configuration
    [2k miles on engine since rebuild]
    81.5mm stock block
    ARP rod bolts, Head studs
    oem HG
    oem lightened flywheel
    KMS block guard
    2000 SI head
    oem IM/TB
    Si int cam
    GSR exh cam [ i have the SI int cam]
    OBX cam gears [6bolt] they work great
    OBD0 oem injectors cleaned by witchhunter.com
    STR cam plug
    ITR oem oil cooler
    GSR oil/water pumps
    FOCUZ header
    exedy 3puck sprung clutch & pressure plate
    CABLE B16 tranny no grinds [used syncromesh fluid]
    90-93 TEG axles with half shaft
    OBD0 starter and alternator included
    THIS ENGINE DOES NOT HAVE:
    WIRING HARNES, O2 SENSORS, ECU, DISTRIBUTER, LINKAGE
    ASKING
    $2,500 + shipping
    MY ZIP IS 32837
    THIS ENGINE WAS BUILT BY J&Y MACHINE SHOP IN KISSIMMEE FL
    I ALSO HAVE THESE ITEMS FOR SALE
    if i sell the engine
    ALL ARE NEW NEVER USED
    UNLESS STATED
    81.5mm cometic lsvtec HG $50 shipped
    OEM b18c5 valvve cover gasket set $45 shipped
    polished b series valve cover [no wire cover] $90 shipped
    OEM oil pan gasket $14.98
    1999 civic si AC/PS & T bracket. $70
    moroso oil pan $143 shipped
    OBD2b SI distributer $167 shipped
    silicone valve guides $89 shipped
    B SERIES hydro to cable mount $179 shipped
    LIKE NEW
    EAGLE Hbeam rods for LS B18 a/b $250 shipped
    they have been resurfaced to like new
    LS SHORT BLOCK $200 might need rebuild
    OBD0 MSD CAP vtec/nonvtec $15
    OBD0 distributer DOHC VTEC...new coil/cap, rotor $35 ea OBO
    TOKIKO BLUE set $200 2k miles
    H&R sport springs $99 2k miles
    1990 integra complete disk brake conversion F&R $190
    includes pads, rotors calipers, rear arms, brake cable
    1991 non rolling crx shell NO rust, dash, plastics,harness, carpet $250
  2. sprayit500
    sprayit500 New Member
    does the obd1 dizzy work? if so do you have pay pal?
  3. formby
    i dont have an obd1dizzy listed
  4. sprayit500
    im sorry bro i read it too fast. wish you did tho. good luck with the sale
  5. formby
  6. formby
  7. smackedhatch
    smackedhatch New Member
    would you be interested in selling the tranny alone?
  8. formby
  9. cheese9988
    cheese9988 Senior Member VIP
    Lowell, MA
    I have an odd request, the bushing for the clutch pedal. Its the peice the pedal pivots on and the mounting bolt goes through. Would you be willing to sell just that?
  10. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    Bump for Formby!
    I might be interested in the DA brakes...
    PM sent
  11. 93vicb16a2
    93vicb16a2 WHATS CRACKIN??
    bfe
    weird one for you
    the plug on the firewall where the a/c lines normally go through on a non a/c car
    would you have that??
    also bump for a great seller
  12. formby
    the pivot thing i need a pic
    andrew why dont you come pick up the crx... ill give you a good price
    and
    the the crx had ac so it doesnt have the plugs
    thanks for the bump guys and i could not be a good seller with out such great clients... thanks
  13. Andrew
    Tallahassee, FL
    C'mon man, don't tempt me!
    I mainly just need to upgrade my brakes.
    I wanna find a complete shell or something... I wanna at least have a dash! :D
    LMK what you can do for me about those Brakes. I'll come down and pick 'em up if you want.
  14. 93vicb16a2
    bfe
    bump thanks for looking anyway
