TEXAS Honda-Tech Meet – Auto-x / Drag / Meet
Discussion in 'South / Southwest' started by civais, Aug 16, 2005.
  1. civais
    civais Junior Member
    What: TEXAS Honda-Tech Meet – Auto-x / Drag / Meet
    Where: San Antonio Raceway
    When: Sunday November 20th, 2005
    What to Expect: We have put together a full day of racing for drivers at any level, where most of the competitors are H-T members. For many people it’s the first time they are exposed to autocrossing an too long since they have been to a good Drag race. This is a great opportunity to watch or try it for the first time, this event is specifically designed for Street Modified cars that where not built for a specific type of racing.
    We encourage everyone to get out and participate or come enjoy Hondas going head to head!
    Address to use for directions: 3641 S. Santa Clara Rd Marion, TX 78124-6006 210-698-2310
    Time: Gates open at 8am, it stops when there is no more racing left to do
    ***1/4 mile bracket and heads up drag racing
    ***Autocross open to all
    ***Lots of Trophies, Cash, and Prizes to be handed out
    **********INFO ON DRAG**********
    2 Bracket Classes:
    *B1 - 15.00 & Slower
    *B2 - 14.99 & Quicker
    2 Heads Up Classes:
    *All Motor Class - All cars in All Motor must meet noise and safety regulations. Transplants, slicks, lexan, and fiberglass allowed.
    *Power Adder Class - All cars in Power Adder must meet noise and safety regulations. Slicks, lexan, and fiberglass allowed.
    Trophies and prizes awarded to Winner and Runner-up in each of the drag racing classes.
    *All cars must be street muffled. (All cars must meet noise regulations for Saturday Street muffled racing.
    Bracket 1 & 2 Winners: $100 Cash / Championship Trophy
    Bracket 1 & 2 Runner Up: $50 Cash / Trophy
    All Motor/Power Adder Class Winners: $100 Cash / Championship Trophy
    All Motor/Power Adder Class Runner Up: $50 Cash / Trophy
    **********INFO ON AUTOCROSS**********
    Autocross: Open to all Honda and Acura automobiles. Trophies awarded to 1st, 2nd, and 3rd places.
    • NOTE: For all events at San Antonio Raceway the schedule will be pushed back 30 minutes. For example registration will be from 8:00 to 9:00 .
    • 8:00-9:00AM REGISTRATION and TECH open. Pre-registered folks must check-in. Work/run assignments will be announced at drivers meeting.
    • 9:10-9:25AM NOVICE WALK-THRU and COURSE OPEN for walking. (course may be open before 9:30 AM if available)
    • 9:30AM Mandatory Drivers Meeting at the van.
    • 9:45AM First Heat Cars To Grid, First Heat Workers to Report.
    • 10:00 AM First Car out.
    • Generally full day affair.
    • 10 Items to do on Event day
    Class 1:
    Class 2: Acura NSX, Acura Integra Type R, Honda S2000*
    Class 3: Acura RSX-S, TL-S, CL-S, CL-S 6spd*, Integra GSR, Honda 03 Accord-6cyl, Prelude VTEC, Prelude SH*
    Class 4: Acura Integra (non-VTEC), CL V6, TL, RSX*, Honda Civic SOHC-VTEC, Civic DOHC-VTEC*, Accord V6, 92-96 Prelude (non-VTEC)
    Class 5: Acura 2.2/2.3 CL, Honda Civic/CRX Non-VTEC*, Accord 4-cyl, Prelude 83-90,
    (*5 points automatically assessed)
    Modifications and Points Assessments:
    Modification points are added to each car in class. If your car equals 11 points you will be bumped up one class. There is no limit – a car with high level of modifications might move up several classes.
    NOTE: Jack, spare tire, trunk carpeting, and tools are free
    11 thru 23 points – Up ONE Class
    24 thru 36 points – Up TWO Classes
    37 thru 49 points - Up THREE Classes
    50 thru 75 points – Up FOUR Classes
    over 76 points – Class 1
    Wheels/Tires:
    1. DOT – approved tires with tread wear 80 and below (5)
    2. Non-DOT approved tires (8)
    3. Wheels and tires extend beyond original bodywork (2)
    4. Plus size wheels (Plus one, two, or three) (2)
    Weight Reduction:
    1. Replacement non-adjustable seat (2)
    2. Gutted interior Front (3)
    3. Gutted interior Rear (anything behind front seats removed) (2)
    4. Lightweight hood (1)
    5. Lightweight Fenders (2)
    6. Lexan/Plexi glass windows (4)
    7. Remove power steering (2)
    Engine/Drivetrain:
    1. Engine swap (11)
    2. Increased displacement (not to be added to Engine Swap) (5)
    3. Non-OEM forced induction (11)
    4. Air intake system (2)
    5. Cat back exhaust (2)
    6. Header (3)
    7. SFC/VTEC controller/Performance chip for NA engine (4)
    8. Performance Chip/Boost controller for Turbo engine (6)
    9. Programmable electronics/fuel injection system (Includes boost/fuel-timing map) (8)
    10. Replacement pulleys (1)
    11. Lightweight Flywheel (1)
    12. Other internal engine modifications (4)
    13. Ring and pinion change (2)
    14. Add/modify limited slip (3)
    Suspension/Brakes:
    1. Performance non-adjustable shocks (2)
    2. Adjustable shocks (4)
    3. Performance/Lowering Springs (2)
    4. Full coil-over suspension (included adjustable spring perch/spring/shock) (8)
    5. Changed/Added anti-sway bars (2)
    6. Camber plates/bolts/adjustable upper and/or lower arms (2)
    7. Big Brake Kit (includes calipers/rotors/pads) (3)
    Auto-x Prizes and trophies will be listed soon!
    Admission Costs:
    $10.00 - Spectator
    $25.00 – Drag Racing Tech Card
    $25.00 – Autocross
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    So, let me see. I have about 43 points, so everything starts at class 5, right and I am bumped up three classes, which would put me at 3 or 2? Do you count the one you start in, and then three up from that? Or three up including the one you're in?
    Anyway, sounds like fun, my car will be back stateside by then too :)
  3. pissedoffsol
    if its like the one at e-town was... 5 is where you start, 4 is 1 bump, 3 is 2, and 2 is 3 bumps. so you're in class 2.
  4. xj0hnx
    C.C.TX.
    Ouch, that's some stiff competition.
  5. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    I'd be in class 2 as well.
    Fuck that. I've never autocrossed the hatch, but I'm pretty sure I can't drive for shit.
  6. pissedoffsol
    4 dead civics can vouch for that :p
    but yeah, when i speced out my car a year back or so, i was like 100 points over the highest class. lol
  7. civicious
    Houston, TX
    2. I've only killed 2.
  8. xj0hnx
    C.C.TX.
    Wheels/Tires:
    4. Plus size wheels (Plus one, two, or three) (2)gotta do the math, but I am pretty sure I am plus at least one size
    Engine/Drivetrain:
    1. Engine swap (11)
    4. Air intake system (2) Does a modified stock box count ie: KN filter, removed resonator
    6. Header (3)
    12. Other internal engine modifications (4) OEM CTR cams count, or just aftermarket, since effectively it is still an OEM 1.6 DOHC vtec
    Suspension/Brakes:
    4. Full coil-over suspension (included adjustable spring perch/spring/shock) (8) So woud Tokicos with GCs be a sum of these three?
    5. Changed/Added anti-sway bars (2) What if you added a OEM sway bar to car that the originally didn't have one, but another trim of the same chassis did?
    7. Big Brake Kit (includes calipers/rotors/pads) (3) Would a GSR brake swap count as a "Big Brake Kit"?
  9. Lantis
    Lantis Senior Member
    Fort Worth, TX.
    I would be in Class 5. period.
  10. phunky.buddha
    Dallas / Fort Worth, TX
    Damn. My Civic would have competed in Class 1. :p
  11. xj0hnx
    C.C.TX.
    That's why it's blank, they left it for you :lol:
  12. phunky.buddha
  13. reikoshea
    Dallas, TX
    class 3...that is soooo un fair.
  14. SixtySecondAssassin
    Austin, TX
    texas is gay. i hope i have a new clutch by then. then everyone can see how slow i am.
    i thought if you swapped in engines in from a higher model car(dx to ex) you could compete in the same class. maybe thats just scca?
  15. reikoshea
    Dallas, TX
    didnt think about that...yeah, my lude started off as an Si :)
  16. phunky.buddha
    Awww c'mon man. Texas is great! Austin specifically... east Texas is gay. :p
  17. Xaero3953
    Xaero3953 Senior Member
    Ft. Worth, TX
    Hell yeah, My car should be up and running by then, I'm there.
