The Black Box on the Back of the Block??
Discussion in 'General Tech and Maintenance' started by rfrumusa01, Nov 13, 2007.
  1. rfrumusa01
    rfrumusa01 Bean Cakes
    Rochester, NY
    Ok, so what the hell is the black box on the back of the engine block?? Need to know what the hell that is and what it does. Need to know. Because it is loose. BTW... D16Y8 engine, 97 Civic. Anyone??
  2. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    metal box? rubber hoses going to it? i think from some of your other posts your runnin the bosted sohc? well on my B16A it's a recirculating catchcan of sorts, from the factory. 1 line for vacuum, 1 line for crankcase ventilation. Then the bottom has a large pipe like connection that goes into the back of the block to the thing under the crank, above the oil pan, girdle or w/e, can't remember at the moment. But basicly routes back to the oil pan. If this is what your asking about...
  3. Hittnthebz
    Hittnthebz New Member
    It is a charcoal canister. The pcv valve attaches to this and it helps reduce emissions from what I understand.
  4. rfrumusa01
    Rochester, NY
    Ok, cool. Well if it is loose, would it possibly be the cause of oil leakage? I have oil all over the drv. suspension somehow, and cannot figure out where it is coming from. Not power steering fluid. Oil. I know the oil return line from the turbo has a slight drip, but that is way to far away from where I am seeing oil, and it does not leak enough. I'm going to tighten that crankcase vent. box u call it anyway, but if it were loose, would it cause an oil leak??
  5. rfrumusa01
    Rochester, NY
    Thanks so much... appreciate the help guys. Hopefully that is the source of my leak.
  6. Hittnthebz
    Sorry, I think I mixed that up with the black canister on the firewall.
  7. Matts96HB
    Matts96HB . Moderator VIP
    ^ Canister on the firewall = teh bitch
    damn thing killed my gas mileage when it was unhooked lol (i didnt know it was unhooked)
