Originally posted by pissedoffsol@Oct 10 2003, 05:34 PM
at WOT, the honda ecu is in open loop, using set fuel maps
and timing maps. So the timing at WOT is going to be the same if using a stock honda non-turbo, afc hack, or a fmu setup. The only time timing will become an issue with the afc hack is at part thorttle and low rpm and in boost. and thats where the btm comes in.
Hmmmm, ive just been told high compression and boost can cause detination.... and that retarding timeing helps get rid of that.... i would like to run around 8 psi with the stock b16a c/r....... depending on where the 14b spools, (hopefully not before 4k rpm's) i doubt i'll ever be in boost while just piddling around town....
is it worth it? if i can get it at a cheap price.....
