cxjon
most of you know that my civics cx motor went to shit a week and a half ago so i decided to swap in the motor i got with my tranny i bought from sean john this past summer. well is swapped it easy as shit but it turned out the motor had bad cr( we should of checked it before we swapped it in ) so we took it out and then we popped the head off my cx motor an saw that there was four valve relifes so we went out and bought a new head gasket and and valve seals and then we popped the head off the dx motor cleaned it up and poped the mother fucker on my cx motor bolted up and put the tranny back on and i took off for home so i can work in the morning. so this morning my friend tom dropped it in and finished it up so the cx beast is now running it is running on the cx ecu but after work it will be running with the dx ecu everything seems to be fine with the motor and working well so i will tell you all if anything goes wrong
