A slight difference in lobe size on a stock cam shouldn't mean it is diferent. two different size lobes could give the same specs , depending on the difference between the high and low points of the lobe in relation to the rocker.
Usually with a reground cam , you don't want larger , you want smaller. The cam is measured from the centre out . When a cam is modified to give it more lift , it is undercut .
The non contact side is ground so that when you adjust your valve clearance , it takes up the slack from the grind. As the cam turns , the valve is pushed further by the amount that was ground off .(depends on rocker ratio)
So with a modified cam , the lobe is smaller .
Duration is a different thing.
