Hello guys ! Any body can tell me the differences between the JDM USA and the Europe version of the ITR ? (Hp, Moment and parts) Thanks.
Did you even bother to look here first? ---> http://hondaswap.com/reference-materials/honda-engine-list-29128/
Typical arrogant HondaSwap reply. Haven't logged into this shit-hole for months and the first thing I see is arrogance. I guess things haven't changed a bit around here. Any of you guys ever get laid? shit.
Yes Dark i did !! Maby you can tell me where do you see the B18C6 engine in this list ??? and where exactly r the explaintion about the mechanical diferences between them ???
well its good to see ppl are actually using the Referrence section. As for the B18C6, you're right its not in that list, B18C6 VTEC Found in: 1998-2001 Honda Integra UK and Euro Spec Type R Type: 1.8 litre 16v DOHC 4 cylinder in-line Displacement: 1,797 cc (109.7 cu in) Compression: 11.1:1 Air intake diameter: 62 mm (2.4 in) Bore: 81 mm (3.189 in) Stroke: 87.2 mm (3.433 in) Rod Length: 137.9 mm (5.429 in) Rod/Stroke Ratio: 1.58 Power: 190 PS/140 kW @ 7900 rpm & 131 ft·lbf/178 N·m @ 7300 rpm Redline: 8400 rpm Rev-limiter: 8700 rpm Vtec engagement: 5700 rpm Transmission: S80 w/LSD As far as mechanical differences, be more specific.
Is 190PS = 190Hp ? In mechanical differences i mean the mechanical reasons to the differences in the Power and moment for the different types of ITR's engines - they all are the same engines so which parts make the different outputs ? Thanks.
ps is the symbol for pferdestärke, which is German for horsepower. The symbol ps is used in both the German and Japanese markets. pferdestarke is the same as metric horsepower, or I should say ps is the symbol for metric horsepower. 1 pferdestarke = 0.9863201 horsepower [international] 164 pferdestarke = 161.7564919 horsepower [international] As you can see, ps is very close to regular horsepower. If you just need an estimate, you can interchange them. 164 ps = 164 hp
