The HRTuning TunerView II Real-Time Display LCD
Discussion in 'Vendor Classifieds' started by HRTuning, Jan 2, 2010.
  1. HRTuning
    HRTuning New Member
    Phoenix, Arizona
    Haven't heard of the TunerView display yet? It's an inexpensive way to see all of your data in real-time without having to lug a laptop around.
    *It's a real-time LCD display that interfaces directly with the ECU to show each systems specialized features (RPM, Duty Cycle, MAP (Vac/Boost) in your favorite units kPA mBar PSI inHG, TPS, ECT, IAT, VSS, PWM, Inputs, Outputs, Special Features Of Your Engine Management, and more).
    *Show up to 8 items per page or one large item to fill the entire screen.
    *Wideband support to display A/F Ratios!
    *Program inputs to display values for your custom sensors like EGT, Oil Pressure, Fuel, Any 0-5v sensor can be used!
    *Disable Injectors on NepTune RTP.
    *Check codes on all OBD1 Systems.
    *Clear codes on ALL supported systems.
    *Backed by HRTuning's awesome support!
    **It supports NepTune Chip Based, NepTune RTP, Hondata S300, Hondata K-Pro, eCtune Chip Based, eCtune RTP, Crome, and even Uberdata (Requires latest datalogging script).
    **Use the TunerView to datalog through on NepTune Chip Based, NepTune RTP, eCtune Chip Based, eCtune RTP, Crome, and Uberdata so you can see everything on the PC software and LCD at the same time.
    The TunerView comes in two sizes that can be installed anywhere you want:
    Small Display Starting at $139: Find Out More
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
    Dimensions:
    And Large Display Starting at $159: Find Out More
    [​IMG][​IMG]
    Single DIN Faceplates available for large displays.
    Customer reviews? Just take a look at these installs!
    If you have any questions feel free to PM or post!
  2. TurboMirage
    that is friggin cool. got one for a mitsubishi running emanage?
  3. HRTuning
    HRTuning New Member
    Phoenix, Arizona
    At this time it only supports the systems mentioned above. We're in the midst of expanding support, though. emanage will be looked at as a possible option.
  4. TurboMirage
    see if you can use evoscan/evotune also. that would really draw in the mitsubishi crowd.
  5. RoughKnight
    RoughKnight Christmas Car
    Ottawa, Ont
    that actually looks pretty good...wow
  6. HRTuning
    HRTuning New Member
    Phoenix, Arizona
    I'll definitely look into. Thank you.
    Thanks!
  7. eg6sir
    nice piece... if i needed something like that i'd be all over it.. good price too
  8. HRTuning
    HRTuning New Member
    Phoenix, Arizona
    Thanks. Affordable and useful was what I was going for with this product.
  9. awptickes
    MD
    Can you give me some information on how it interfaces with the k-pro?
    I'm looking into whether or not this would be useful in my Fit.
  10. Matts96HB
    Matts96HB . Moderator VIP
    Ohhhh I'm so tempted. That'd look nice in my EJ :)
  11. HRTuning
    HRTuning New Member
    Phoenix, Arizona
    It uses a USB cable from the interface module to the K-Pro, the same USB cable you tune with.
  12. HRTuning
    HRTuning New Member
    Phoenix, Arizona
    There hasn't been a car it doesn't look good in yet. :)
