<_< so i have a ctr in my 98 hatch and at about 4000 rpms it sometimes is cutting out or other times just as the vtec kicks on and as soon as i shift into 2nd gear it is almost like im hitting the rev limiter but im not even close what could my problem be?
check your codes, go to www.hondata.com they tell you how to check your codes and give you a list of what the codes are, sounds like you're hitting the soft limit or whatever you wanna call it, its your ecu trying to save your engine, try that and see what you get.
