UPDATES!
Click the link in my sig for todays/yesterdays updates! I figure doing it that way will keep the build page a little cleaner and more 56k friendly.
Rear suspension installed (neuspeed sports over KYB AGXs)
Wicked tuning LCAs installed
SIR-G full brake/suspension front rear is up and running
Russel stainless brake lines installed
I also ordered a binks rear EG sway install/brace kit. That will allow me to finally bolt up my ITR rear sway bar.
P.S. Installing a rear sway bar on an EG with no factory sway is pure hell on your wallet. ITR Sway bar and end links: $65 used. New bushings from ES: $20. Wicked LCAs (so you have mount points for the sway bar) $100 Binks rear sway install/brace kit (required so your weak ass subframe doesn't tear, and for mounting points, as the CX doesn't freakin have any) $70
So, all in all, in order to add a rear sway to an EG, look at spending a minimum of $255.00 A far throw from my original $65 plus nuts and bolts, which is what I was thinking.
