Doesn't look too bad here, but the bumper is cracked under the license plate
Headlight is pushed back and hood id pushed down here
See the problem here? Yup, slightly bent in the front
Driver side headlight mounting tabs(all four) broke off, but actual headlight housing is cool. I'll have to figure out a way to mount it up temporarily.
Damaged goods
Driver side fan also sounds like a baseball card in a bike wheel when it kicks on. Luckily the two fans are powered separately so I just unplugged the driver side for now. I'm in a good mood though. Removing the bumper had a few snags that allowed me to justify buying a Craftsman rotary tool. Needed it for two stripped bolts and the license plates bolts that are rusted, stripped, and need to be replaced.
So tomorrow everything goes back together with a little modification and customization. Basically make it functional for now and if I feel like taking a crack at bodywork later, I'll handle it then.
Who knows, maybe a JDM front clip is in this car's future. New front end, a "fresher" motor, and a transmission swap in one shot...
