The Sol Is Leaking
Havok
After some heavy rain these last 2 days, I went to work today and turned on the a/c and some water started leaking on the carpet under the glove box, close to the ECU. It stopped when I turned off the a/c, but it did it both times I turned the a/c on, once at 2 pm and once at 10:30 pm. I felt the underside, behind the glove box, and a lot of it is wet...I haven't checked it out yet, but any suggestions?
i had the same problem. part of the air ducting was a little disconnected under the glove compartment. the moisture was just condensation from running the a/c.
