The Trak Kaa at Thunderhill; 2nd in TTB!
Discussion in 'Auto Multi-Media' started by B16, May 20, 2011.
  1. B16
    B16 Super Moderator VIP
    yay area, CA
    Got 2nd in TTB last weekend before spinning the rod bearing on #4 from oil starvation on turn 8. The beginning caught a glimpse of a F430 Scuderia flying by me on my warm up. 2nd part is me making my way from the back of the pack (came to grid late).
    Love the new power of the motor and grip of the tires/suspension. Wish it would have lasted longer. I need to rebuild this thing before the next race on July 2nd.
    Enjoy!
    YouTube - ‪moutlandNasaTTB051411.wmv‬‏
  2. Matts96HB
    Matts96HB . Moderator VIP
    nice driving! second guess yourself going to pass that miata? lol looked a little tight
    any idea what caused the oil starvation?
  3. B16
    yay area, CA
    Yes, totally 2nd guessed that pass as it was tight there. I realized he was aware I was there so went for it.
    Oil starvation was caused by the following.
    • Excessive crank case pressure pushed oil into catch can
    • Catch can had no drain back so oil just accumulated into the catch
    • Hard left hander, engine fell out of VTEC and I noticed oil pressure was down around 25psi so I let off
    • Oil pressure came back to around 55psi so I limped into the paddock
    • As soon as I came close to my spot, I heard a rod knock, killed the engine and pushed it into my parking spot.
    • check the oil and nothing was on the dipstick.
    • found about 2qts of oil in my catch can.
    #4 rod bearing fried. Needs a new crank as well.
    It will be rebuilt and ready for the next time trial event on July 2nd.
  4. Matts96HB
    yea i saw that he kinda let off, or moved over somewhat.
    road racing looks like so much fun, i need to get out on a track :(
    sounds like the catch can needs a little work. did you vent the block and the valve cover?
    sucks you spun a bearing, and you just got done rebuilding the engine didnt ya?
  5. B16
    yay area, CA
    Catch can does need work. I plan on doing the following.
    Larger catch can
    Drain back to oil pan
    add 2 vents to front of VC
    block off and remove the black box on the block.
    Hopefully that takes care of it. I'll be watching it closely at the next event.
    This was only the 3rd event on the engine since the rebuild; had about 200 or so miles on it. :(
  6. Matts96HB
    some people vent the block as well, you might look in to that. the black box on the back is usually where they do it from. i think most run two separate catch cans.
