Got the exhaust mocked up, pieces trimmed to bolt everything up to the downpipe, just need to weld it up tomorrow.
Installed the catch can, it looks like the pcv needs to be replaced, I suppose I'll buy one tomorrow. It's hooked up to the head vent and the PCV with the vacuum source being the compressor inlet. I just zip tied it to the AC lines for now, I'm going to have to make a bracket for it.
I got the turbo drain line figured out, oil pan drilled, and now I just have to weld that as well. I'm welding an AN10 bung on it. Hopefully one of the garbage AN10 45° fittings won't be total garbage, and it'll spin, tighten, seal, and otherwise work correctly.
I had to pick up an AN4 90° fitting to get the turbo feed to fit, and it has to be fed from the passenger side. So, I may need more than 40" of line to feed it, which sucks because all I have is a 36" and 40" line.
Left to do:
-Weld up exhaust pieces to make the down pipe fit the mid pipe.
-Weld up the drain fitting on the oil pan. I'll probably just TIG Braze it with silicon bronze filler, to reduce warp and heat.
-Weld or clamp up an extension to the wastegate to get it out of the engine bay.
-Change the oil, attach the turbo feed line, replace the PCV
-Put the colder plugs in.
-Connect the wbo2 and figure out if I want to run a narrowband.
-Connect the lines for the wastegate, blow off valve, and boost gauges.
-Drill charge pipe and insert IAT gauge.
-Connect the ECU, load the basemap, and start it up to check for leaks.
-Reinstall the passenger fender, bumper, other plastic thing, and the fender liners.
-Try not to blow it up data logging enough to street tune it well enough to drive to the dyno 20 miles away.
-Schedule Dyno time to tune it.
I should be done by the fourth of July.
