Thermostat questions.
jamesA
Thank you for your business.
VIP
I need some help. I called the gas company and they say that the gas was never actually shut off. So I flipped the valve open and turned the breaker/light switch on to my furnace. When I turn the tstat to heat, nothing comes on. but when I turn the fan on it blows cold air (obviously).
So I decided to switch the old tstat out with my honeywell programmable one.
I have it set up as it should be, all the color wires are on the correct terminals.
Red - R/Rc - power
White - W - heat?
Yellow - Y - cool?
Green - G - fan
I know the red is power and the green is fan, but I can't recall which one is heat vs cool. I know it's hooked up correctly according to the directions, though.
Blue - unhooked as it was. I apparently have a four wire system, it says on a 5 wire system I'm supposed to unhook the bridge between the R and Rc pins.
With and without the bridge I can't get the heat to blow, any suggestions? It's like 38 in my house right now and my hands are still numb from the 20 minute drive.
When I opened up the furnace it's on and seems to blow some air, and had a light or whatever on, but no real heat is coming out.
Nobody has ever put in a thermostat or had this problem? :(
and boo to all of you being asleep.
Is there a main valve on your gas meter? It might have been closed when they left.
If the furnace is running, it should be making heat.
Assuming its a 1 heat/1 cool stat
with the jumper intact (between R/Rc):
R/Rc: Power
W: Heating
Y: Cooling
G: Fan
Also...MAKE SURE YOU'VE GOT THE RIGHT VOLTAGE
Baseboard heating is usually 120 or 240v
T-stats can be 24/120/240/even 460v
Also, if you have a gas fired boiler, the t-stat might not work with the zone valve (2 wire vs 3 wire)
If you're still having problems, just let me know what model t-stat it is and I'll try to help you out
Ok, I had everything right. The lady that said the gas was never shut off was only half right. I had gas service there, but the main meter was closed. A tech stopped by and flipped it on, my stove works, my furnace works, and shortly my water heater will work when I fix the grommet.
Now I'm getting heat and the furnace is running.
Yes, Heat. I set it for 68 for the time being. let it get warmed up and then I still gotta move the Tstat.
I would have figured you'd get the right answer, living in Alaska and all. :p
Rep for you. heh
Shit. I need to learn about t-stat's and heaters and such. Stuff I have no idea about.
Well I have a gas furnace at the house, the color codes were exactly as I described them. It's apparently not that hard, I had everything right but the gas wasn't on. heh
