Quoted post[/post]]
3rd times a charm.
Yea I forgot to mention that...check out your radiator & have you flushed your coolant lately?
+1 About the only thing you can do to check and see if the radiator is flowing is by getting a temperature gun and checking to see what the temp is on different areas of the radiator and the hoses going in and out or the radiator.Quoted post[/post]]
IF you want to find out if your radiator is clogged, take it to a radiator shop and have them boil it and pressure test it for you. I don't know of any good way of checking it on your own. But check the thermostat first, that's way easier, or do them both at the same time, while the coolant is out of the car.
