This a good or bad one...?
Discussion in 'Forced Induction' started by ovcrash, Nov 3, 2003.
  1. ovcrash
    ovcrash Senior Member
    Quebec, Canada
    It has a .60 A/R intake and 1.15 A/R exhaust with a P trim.
    Good or bad turbo to put on a 97 H22A ??
    and what is the difference between a draw thru setup and a blow thru setup ??
  2. pissedoffsol
    it would be great..... if you want to make 800 hp and spool at 8000 rpms.
    1.15 is HUGE y0.
    and there is no intake or exhaust side to a turbo. its called a compressor and turbine.... and futhermore, i think you have it backwards. usually the compressor is bigger than the turbine....
  3. BigJ
    :lmao: That sounds like a bad ass turbo.
  4. Loco Honkey
    Loco Honkey Banned
    Draw through and blow through refer to turbocharged carb setups. Blow through is far superior to draw through for many reasons.
  5. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    Is it a t2, t3, t25, t3/t4, t4?
    If it's a t25 with those specs, it's still too small for your engine.
  6. pissedoffsol
    to the best of my knowledge, there is no p-trim wheel fitting in anything less than a t3/t4 combo.... so thats what i assumed it was.
    if there are p-trim wheels in smaller turbos, im going to go out on a limb and ask WTF?
    hell, my turbo doesn't even have a p-trim.
  7. ovcrash
    Quebec, Canada
  8. SolReaver
    SolReaver Senior Member
    bad turbo
  9. ovcrash
    Quebec, Canada
    Then if that's a Bad turbo to put on a 97 H22A what would be a good turbo, to obtain 300WHP ??? What would be the A/R for the Compressor and the Turbine??
  10. pissedoffsol
    no need to run anything larger than a .63 on either side for 300 whp. you standard t3/t04e from a drag kit wil give you 100 hp at 10psi or so on the h22.
  11. ovcrash
    Quebec, Canada
    For more HP, i would need a bigger A/R on the Compressor side? Like maybe .70 or .85??
  12. pissedoffsol
    not even. more boost would be the first step.
    my .63/.70 stage 5 (smaller than p) is good for well over 600 horse on a b-series.
