this cant be right
Discussion in 'Civic and CRX - EF' started by lookout 4me, Oct 14, 2006.
  1. lookout 4me
    lookout 4me New Member
    ok so i bought a new intake for my 91 crx dx right. but i went out to install it. i try to pull out the o2 hose from the vale cover then there a two more hose that are connected to it. one i think goes to the thottle body and the other to the intank maniflod. i pulled the hose form the intank off and aintfreeze came out. so i put it back. the thing is that am not sure if i can cut the hoses from the o2 off the the other ones that are going into the intank and body. is the antifeezer getting sucksion from the o2 tube? i need to put the aftermarket tube form the intake on or it wont fit. i know enough about cars to do this but done want to cut some a fuck things up.
    so if any one out there has done this before on a 91 crx dx please help me out.
    thanks for any help. oh and sorry for the bas typing.:(
  2. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    Take a pic and upload it so we can see exactly what you're talking about.
  3. hosmer
    B R I D G E W A T E R
    no, theres no suction from the vent tube.
    it sucks because EF's have the 2 tubes "welded" together with the metal clip in the middle.
    What I always did with my EF's was just cut the vent tube on either side of the metal tab and then just try to hide that coolant tube down underneath the intake or remove both and just use a rubber hose for the coolant line.
    Use the vent tube that came with your new intake
    and, you're talking about this right?
  4. lookout 4me
    yea thats what am talking about. so its safe to go ahead a cut that little black clip on the hoses off? i just thought that thats were the coolent gets its suction from to continue the flow.so those hoses dont have anything to do with each other and the coolent will continue to flow correctly?
    and the pic is a great piture of what i was talking about. thanks.
  5. hosmer
    its not a clip...they're welded together
    it sucks, but they're all like that
    and yes, the two have nothing to do with each other
  6. lookout 4me
    thanks for all the help hosmer. ^_^
  7. SavageDreams
    SavageDreams Savage Reins Supreme
    Taft,Ca,93268
    hey lookout take that two hose metal thing off and grind away the top tube for the air intake with a wire wheel/grinder thats what I did and it worked great but dont grind too much off
  8. igotnothin
    igotnothin New Member
    harford co MD
    my old intake came with a tube for each. aem with the hook up
  9. SavageDreams
    Taft,Ca,93268
    so ur car came with two seperate metal tubes or the two stuck together with the weld if its the welded u can get rid of the top tube for a cleaner look by grinding it off like I said thats what I did and I got alot of "hey man that looks clean"
  10. phunky.buddha
    Dallas / Fort Worth, TX
    I cut mine off with a saw, then cleaned it up with some wrap on top. Easy.
  11. SavageDreams
    Taft,Ca,93268
    lol what ever floats ur boat right if it works and looks good then who can complain right and if they do hey its not thier car is it????I was gonna use one of my cutters but I was paranoid I would slip and cut too much or something so I grinded it since it takes less off at a time.well hey man good luck with your car!!!!!!!!!
  12. BlueCrxNC
    BlueCrxNC VTEC CRX
    Me too!:p
