civiclxb16
OK this swap is pissing me off! one i had an oil leak had to take the timing belt off and all that to get the seal, fine got it in there all good, now we can't get the car to go in gear. it only goes into gear with the motor off, i bleed the line twice, changed the secondary cylinder and still the same stuff the clutch has no miles so the clutch is still good! what could it be? is it possible that we put that clutch fork on wrong? or the throw out bearing wrong? i am so clueless right now!
