This Is My Swap
In a 92 cx hatch: 95-b18b engine and ecm, 00-civic si trans shift linkage and axels.
which mounts should i use for the engine and which for the trans, also what other OEM ecu's will work with my swap? thanx.
Use b-series mounts. Should be an easy swap. LS ecu should work ok. To save on gas, use an LS tranny to keep the revs down while cruising on the highway. But yea, should be a fairly easy swap. Good Luck
