Those of you with 6g civics and swaps
Discussion in 'Members' Lounge' started by Baker, Oct 30, 2002.
  1. Baker
    Baker Senior Member
    Schaumburg, IL
    I have basically no exhaust on my car and am trying to decide what to do. Buy cat back and get it adjusted to fit a cat, get stock integra exhaust and get new hangers welded on, just take it in to a muffler place and have them run a pipe and put a muffler on. I don't want to get anything to fancy since I'm getting a turbo in spring and will just have to replace it anyways.
  2. chet
    chet Senior Member
    st petersburg, florida
    get the apexi world sport. also get a test pipe from www.testpipes.com or have someone at a garage make you one.
    the world sport is 420 shipped
    jason@alljdm.com
  3. Baker
    Baker Senior Member
    Schaumburg, IL
    i don't want a test pipe, no cat smells bad and sounds absolutely terrible
    but will that exhaust bolt right up with a cat and a b series downpipe on a ivic?
  4. Sed8ed
    Sed8ed New Member
    Vancouver B.C.
    If you are getting a turbo, then get the exhaust that you want for the turbo kit and fabricate a way to hook it up to your car. I have the same swap as you and I made my own 2.5" exhaust:
    - 2 mandrel U bends
    - 1 6 foot length straight pipe ( they only had 6 foot lengths)
    - 2 butt flanges ( not necessary but I want to be able to remove the cat)
    - 1 spring flange (I can't remember what this is actually called but it goes right after the header and compresses around the donut seal)
    - 1 borla 2.5" muffler
    - 1 nice 3" tip
    - 1 magnaflow high flow 2.5 inch cat
    - 1 mig welder
    - 2 cans of high temp exhaust paint
    - 1 3 foot length of 1/8 hot rolled steel rod (for hangers)
    Just cut the u bends to match the angles of your stock exhaust, use the straight pipe for the main section, weld the cat towards the front of the exhaust, so forth and so on, if you really want to do this i'll write up a better discription if you so need but it looks great on my car.
  5. E_SolSi
    get a random tech (or other aftermarket hi-flow) cat and modify the flanges
  6. Baker
    Baker Senior Member
    Schaumburg, IL
    I want 3 inch for the turbo and I thought running anything over 2.25 right now would be to big on N/A
  7. Sed8ed
    Sed8ed New Member
    Vancouver B.C.
    oh yeah, total cost was about $270 plus a little for the gas for my mig welder,
  8. Sed8ed
    Sed8ed New Member
    Vancouver B.C.
    I wouldn't worry about it, you will lose a little performance wise until you get the turbo but cost wise... just get the 3 inch. 3 inch piping and bends are about $2 more per piece, the high flow cat is the same price and the muffler should only be about $10 more.
  9. Baker
    Baker Senior Member
    Schaumburg, IL
    how hard was that to do, I have never done any kind of welding before nor do I own a welder
  10. Sed8ed
    Sed8ed New Member
    Vancouver B.C.
    It wasn't too bad actually, my dad own's a mig so I used his but I think you can rent them. Took me about 8 hours in total but some of that was fuck ups. The first thing I did was get a piece of sheet steel and practice doing weld lines down it to get the feel of the welder then I went to work welding the piping together. Ask around if someone knows how to weld and give them a case of beer to do it for you if you want.
  11. Baker
    Baker Senior Member
    Schaumburg, IL
    hmmm, my friend is a sprinkler fitter maybe I should make him do it for me, that or go to an exhaust shop
  12. Sed8ed
    Sed8ed New Member
    Vancouver B.C.
    An exhaust shop will usually charge you an arm and a leg to custom make an exhaust kit for you... ask your buddy
  13. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    It cost me less than $200 at my local muffler shop to get an exhaust run. Looks good, sounds good, no rattles.
  14. Baker
    Baker Senior Member
    Schaumburg, IL
    theres a merlins next to my buddy's shop, they usually give his customers good deals so I'll talk to them first
    what size piping did you have them run? and what muffler did you use
  15. dohcvtec_accord
    The left lane
    I went with 2-1/4" piping, but 2-1/2" would have been very close in price. Got a Dynomax muffler. A touch high-pitched, but nothing like a fartcan wide-open exhaust, and a 2.2L engine has a tough time sounding like a weedwacker. :D
  16. cxjon
    cxjon Senior Member
    man+k+toe
    it cost a 120 for my friends car like mine plus the muffler!
