Thoughts on an ITR 5 bolt conversion
Discussion in 'Wheels / Suspension / Tires / Brakes' started by GlassHeadlights, May 16, 2013.
  1. GlassHeadlights
    Calgary, AB
    TorontoJDM.com - Total Japanese Domestic Motor - DC2&EK9 5 BOLT DISK CONVERSION
    I already have a complete GSR brake conversion on my coupe, but it's a complete GSR conversion on my coupe with 220,000 miles, so it's not performing like it did in '95. I need a brake upgrade because cheap ass shit tits remanufactured calipers are like $200 each so that's like a $1000 brake job by the time I do nice pads and rotors after. I also auto-x and had my brakes smoking pretty badly last event.
    I already have a newer GSR 1" master cylinder and a 4040 proportionig valve from a DA Integra.
    I read for the JDM 5 lug you must use 36mm axles so that may be a bitch to source when one goes out on me. The link I posted supplies the axles. And I assume they will work with my GSR mid shaft, correct me if I'm wrong.
    Also when I need pads, rotors, calipers, ect. do they share the same parts as USDM ITRs?
    I spent a bit of time trying to look this up over my phone but I'd like to pick your brains as well :)
  2. GlassHeadlights
    Calgary, AB
    Until I did my researchin' I wanted the 4x114.3 conversion but I suppose they have the same brakes as a GSR but accord wheels :<
    Oh yeah and I know all about the LCA deal lol
  3. E_SolSi
    its damn near impossible to find good lightweight 15" wheels for the ITR pattern and offset :(
    you are pretty much going to have to move up to 16" if you want a good set of lightweight wheels
    or find an old set that someone is selling for way too much money and pray that you never fuck one up and need a replacement
  4. GlassHeadlights
    Calgary, AB
  5. GlassHeadlights
    Calgary, AB
  6. phunky.buddha
    Dallas / Fort Worth, TX
    Doooo eet! Then you can cram some 255/40-17s in there on some 17x9s. :D :D :D
  7. GlassHeadlights
    Calgary, AB
  8. invisibledemon
    Tn
    personally, i would just buy a big brake kit that bolts up to the existing hub, benefits of a much better braking system without the hassles of wheels and axles. also, if you are autox'ing, you should look into installing vents to direct air to the brakes.
  9. GlassHeadlights
    Calgary, AB
    Fastbrakes I think they're called? And yes I had a guy mention that to me, I would like to buy front brake ducts that funnel air through the fake eg vents
  10. eg6sir
    i had 32mm ITR 5 lug spindle swap not too long ago.. sold it locally tho
  11. Briansol
  12. eg6sir
    google naca duct for venting
  13. GlassHeadlights
    Calgary, AB
    No budget in mind anymore, I have good money coming in now. And yes, I have a set fat fives, Drag DR16s with slicks for the track and Kosei K1s for daily
    Thanks I couldn't find then on eBay
    I am now thinking of a fastbrakes kit with extended studs, new wheel bearings, steel braided lines, good pads and rotors
    Which size rotor do you think I can fit user my selection of wheels?
  14. |Chaz|
    |Chaz| Well-Known Member VIP
    B16 knows his brakes also. I run the stock calipers on my car with Brembo blanks and Hawk pads and never had any smoking or over heating issues :dunno:
  15. Briansol
  16. GlassHeadlights
    Calgary, AB
  17. phunky.buddha
    My FastBrakes 11" kit with the Dynalite calipers fit under the fat 5s... BARELY.
  18. GlassHeadlights
    Calgary, AB
    So would anyone know where I would get these brake ducts just made out of plastic, not carbon fibre, and for less than $150 each?
  19. eg6sir
    Looks like Naca ducts arent around anymore.. they had a large assortment of sizes
  20. eg6sir
    Jhp has them for $120/each
