Thread size on a TD04L Turbo
Discussion in 'Forced Induction' started by 92CHB, Apr 10, 2005.
  1. 92CHB
    92CHB Senior Member
    Easthampton, MA
    I was wondering if anyone knew what the thread was on the center section of a Mistu TD04L turbo for oil feed and return. THANKS!
  2. pissedoffsol
    are you sure its from a wrx? every wrx/sti turbo i've seen starts with VF__ as the name.... and i don't think they are mitsubishi turbos either...
  3. 92CHB
    92CHB Senior Member
    Easthampton, MA
    Yup its from a 2002 wrx. Its got the mitsu diamond on the exhaust housing. I forget where to check turbo serial numbers(used to be some website). But i am 100% positve its from a 2002 wrx.
  4. cycloneb18c3
    cycloneb18c3 Senior Member
    New Jersey
    I think the turbo hes got says TD04L on it. Ive got the same thing sitting in my garage I belive, Ill have to look and see what tread it is.
    Ill let ya know as soon as i get a chance.
  5. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Yup, it's definitely a Mitsu TD04 turbo (although I've heard debate about exactly WHICH TD turbo it is). All non-STi's come with it. The STi comes with the IHI VF39. The IHI VF turbos are a favorite upgrade because they're not very large and have an internal wastegate.
    Don't know about the thread size though, sorry. :(
  6. 92CHB
    92CHB Senior Member
    Easthampton, MA
    I just searched the hell outa HMT.com and found out that out that the thread is m10X1.5...what type of fitting would i get then? anyone know...i want a barbed fitting and all the places i look are either NPT, BSPT, etc. Ayone know what that thread converts to?
  7. pissedoffsol
    contact stan@fast-turbo.com i bet he can set you up with a whole kit. he specializes in fittings/oil lines
  8. 92CHB
    92CHB Senior Member
    Easthampton, MA
    Okay thanks! The only thing i need is that barbed fitting since i already have the line and stuff. Thanks for all your help. Alos thread conversion of 10M x1.5 anyone know?
  9. 92CHB
    92CHB Senior Member
    Easthampton, MA
    Okay found an 10mm x 1.5 to 4 AN adapter fitting on summti... Is 4 AN too big for the oil feed? whats the best AN size for it? I read somewhere that 4 AN = 1/2", Sounds too big to me. :huh:
  10. pissedoffsol
    you want -3 for a feed line.
    get a 4-3 convertot
  11. 92CHB
    92CHB Senior Member
    Easthampton, MA
    Well i found a adapter fitting on summit and a barb fitting to match. So i am good to go. Thanks for all you help!
  12. 97hatch
    97hatch ?
    Anderson IN
    you probaly should lok into a m10x1.5 banjo to -3 if you use a straight fiting you will have sealing isues unless you can find a oringd washer to fit it
  13. 92CHB
    92CHB Senior Member
    Easthampton, MA
    So you saying i should use a crush washer with the adapter fitting?
