Throttle Body Clean out??
Discussion in 'General Tech and Maintenance' started by Jazzy19, Sep 27, 2005.
  1. Jazzy19
    Jazzy19 Senior Member
    Hey Guys,
    Quick question, I googled how to clean out my throttle body, but only came up with generic steps to take on how to clean it out. I was wondering if anyone could post some quick instructions on how to properly clean your throttle body. Oh by the way i drive a 99 B18B auto...
    thanks for you help guys,
    Jazzy19
  2. formby
    formby learning in progress
    step one remove TB
    step two pick up parts cleaner
    step three spray parts cleaner
    step four wipe TB
    repeat as needed
  3. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    :withstupid:
    It's REAL simple. Just be careful when removing the TB if you're planning on reusing the gasket.
  4. phyregod
    phyregod !!YTINASNI
    Central Texas
    If possible, always replace the gasket after removal.
    my 2c.
  5. Xaero3953
    Xaero3953 Senior Member
    Ft. Worth, TX
    :werd:
  6. Jazzy19
    Thanks boys.. i will try that and let you know how it goes....
  7. confusatron
    confusatron Senior Member
    Chicago area
    You don't necessarily have to remove the throttle body. You can always just take off the air hose and spray the inside of the tb from there. I did this to my camry, same setup, and it worked great. You don't really have to worry about the dissolved gunk getting into your air intake much. just spray, wipe, spray, wipe, etc. I just held the throttle flap open with a fat wrench to get both sides of it clean. It shouldn't take too long. You might not get it as perfectly clean as if you take the whole throttle body off, but it'll be good enough not to have to worry about it.
