Throttle Body Port Polish
auggiereg
Member
I just bought a throttle body from a 95 Civic Si for my Dx and I wanted to know where and how much it would cost to get it port and polished. Southern California locations are preferred. More precisely anywhere near West Covina would be even better. Thanks for the info.
Originally posted by pills_PMD@Apr 29 2003, 10:27 AM
you should just put a 60mm b series throttle body on it... more cost effective.
Easy cheap and effective. Any OBD1 B series would work well.
I already bought the thing and has been shipped to me. If I were to port and polish it would I also need to port and polish match the intake manifold? The throttle body is already at 62mm would it be pointless to port and polish it?
From my site, Re-measure it on the side that goes to the Manifold it's only 56mm stock, I'm sure it wasn't bored out to 62; however if it is, it's already ported and yes you wil need to port match the manifold. It's easy to do yourself. Put the TB on the IM and mark it with a marker, then dremel it out.
Honda/Acura Throttle Body Inside Diameters (in mm)
B18C1 60
B18C5 62
B18A 58
B18B 60
B16A SiR 58
B16A SiR2 / B16A2 60
B16A3 58
B20B/Z 60
F20C 62
D15B7 56
D16A6 55
D16Y7 56
D16Y8 56
D16Z6 56
ZC 55
D16A1 55
D16A8 55
H22A / H23A 60
F22/ F23 60
Note most Honda Throttle Bodies are tapered and the outside diameter is larger than the inside diameter
