throttle body question
chap_e77
Member
I have a b16a1. I need a throotle body that has the map sensor on top of the throttle body what will fit. right now i dont have a map sensor running. Also I cant find the plug for the map. I have an external map with a 3 pin plug. The plug I thought that went to the map sensor is only a 2 pin. Can anyone help me out on this. Im new at this type of stuff.
now would be a good time to send it out to get bored and get a new tps, and all components on the TB replaced such as the throttle plate and screws.
you dont need one that has the MAP located on top, but if you want one, get an ITR throttle body.
you will still have the same problem that you dont know where the plug is for the TPS... did you plug it into the IAC valve perhaps??
honda MAP sensors did not change between obd0 abd obd2 so any map will have teh same amount of pins (3) and require the plug that you somehow lost on your harness.
just run a vac line to the MAP you have and find the plug... its there
and mount the MAP on the firewall
