throttle-body swap???
Discussion in 'Civic and del Sol - EG and EK' started by danny94eg, Feb 21, 2010.
  1. danny94eg
    danny94eg New Member
    what im wondering is can a D-SERIES throttle-body fit on a B18A/B intake manifold??? everything looks the fairly the same buy looks... i got a t-body from a d16z6 does anyone know if it will fit??? or if the diameter is ok for b-series ls???
    94 civic hatchback cx
    93 B18A1 w/ SI trans.
    OBD1 PR-4 (sohc vtec wire harness)
    symptoms:
    stalls after crank on cold start!!!
    warm start revs to 2500 for a sec. then lowers to 800
    my thoughts:
    there is no FITV on the b-series t-body!!
    tests:
    cranked and pumped gas pedal, engine fires, i hold the gas down at 3000rpm until engine reaches running temp...... IDLES FINE!!!!! and i drive!
    if i dont hold it til runtemp. it will stall
    feedback:
    (**thats you** lol):)
  2. zach_teg_king
    zach_teg_king jdmzach "country boy"
    south central, KY (amishland lol)
    no bc the d series tb is 5mm smaller than your b series
  3. eg6sir
    it will fit and work ..... but like dude above me said .. they're different sizes
  4. arbordk
    arbordk New Member
    Would a b16 SIR TB off a 00 civic SI fit a D16A6 intake mani ? I know the intake mani would need port matching because of the size diff.
