Throttle body
Discussion in 'HYBRID -> ED-EF / DA' started by 90'CivicSi, Aug 29, 2008.
  1. 90'CivicSi
    90'CivicSi New Member
    I dont think anybody likes answering my questions but ill keep trying until someone does. Would an DA LS throttle body fit on D16A1 motor or how bout a B16A fit on it. Just looking for some help
  2. efhondakid
    Akron-Canton, Ohio
    It will fit, but you wont gain a thing from it, the extra size of the B-series is too much for a stock D. TB size needs to be matched to cam profile, do you have an aftermarket cam? If not then your stock TB is perfect for your motor.
  3. 90'CivicSi
    No i wont have aftermarket cams in the motor when i get to working on the motor i wanted more variety of aftermarket TB to put on it instead of finding them just for the D but if the B fits i was going to do that for more air through the motor for the turbo itll have on
  4. efhondakid
    Akron-Canton, Ohio
    Again in case you missed it, your TB needs to be matched to your cam profile, your cam profile should be matched to you turbo. Understand, you cant just throw parts onto an engine and expect gains it all has to work together.
  5. jlicrx
    jlicrx Senior Member
    Colorado Springs
    the only throttle bodies that fit the D16A1 are the D16A1, 88-91 CRX/Civic Si/EX D16A6, JDM "browntop" DOHC ZC or JDM 88-91 DOHC ZC - B-series throttle bodies have a different bolt pattern
  6. 90'CivicSi
    How would i know if it fits my cam profile or not
  7. efhondakid
    Akron-Canton, Ohio
  8. 90'CivicSi
    oh so would i be better off looking for JDM ZC aftermarket throttle bodys for that motor or would i better luck with the D16A6 throttle bodies
  9. INJEN78
    INJEN78 HS LEGEND
    OHIO
    bore yours out a little if anything..just make sure to gasket match
  10. celmore
    celmore New Member
    Springfield, MO
    You will be doing a lot of work on the motor if you are trying to fit "cams" in a D
  11. INJEN78
    INJEN78 HS LEGEND
    OHIO
    no more talking from you...
    d16a1 is DOHC
  12. 90'CivicSi
    thanks for clearing that one up on the DOHC did someone answer about the DA LS throttle body on it
    i didnt think anyone did
  13. 90'CivicSi
    oh thanks for all the help guys and i got one more question how bout a what other intake mani will fit on that motor as well is the D16A6 mani the same size as the one on the D16A1
