I am looking to replace my throttle body on my H22a engine. I was just wanting to do a bit of research before I did so. Do you recommend doing so. What do you feel the pros and cons are to it. It you do recommend it what size do you recommend 65, 68, or 70mm? <_<
what do you have done that would require or justify a larger TB??? it isnt going to do much for you unless you have a bunch of other shit already done
Intake manifold will be done at the same time, but i am just looking into things right now because I have my Engine on a stand right now and i want to do that kind of sh!t before I put it in because it will be much easier.
unless you have an intake, header, exahust, high flow cat or lack of one, ported head, larger cams, larger valves, and the intake manifold, you really won't see much of a benefit
actually with just the basics you feel a little something but mostly throttle response which is nice.
