Throttle Cable Swap
Discussion in 'HYBRID -> EG-EK / DC' started by rschoener, Mar 21, 2003.
  1. rschoener
    rschoener Junior Member
    I havw a D16Z6 in my 89 Civic DX hatch. Right now i'm using the old DX throttle cable i tried an integra cable but the inner line was too long. What cable should i be using. The DX is way too long overall.
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    The Z6 one should fit.
  3. i think the 92-93 integra GS-R should fit, i heard on an article about it.
  4. xj0hnx
    C.C.TX.
    Wouldn't a DOHC be too long?
  5. solblu
    solblu Senior Member
    Ricer
    Use one from a Civic with the D16A6. A 88-91 Civic or CRX Si. I just did that today for a D15B87. The 88-89 Integra one will work too, it's just a little shorter and has to be adjusted a little. Get the pieces that it runs through too.
  6. rsaeini
    rsaeini Senior Member
    Los Angeles, CA
    you always want to buy the cable for the motor. if you have a D16Z6, you should use a cable for that motor.
    you can't use a DOHC cable on that motor, it's the wrong lenght.
  7. rschoener
    Thanks.. I'll get a cable from a 95 ex.
