THROTTLE CABLE
mjfubar
Member
what throttle cable should i use on a 91 civic with a b16 swap
Go with the throttle bracket. It works much better. Plug and play. BTW-the nracket from jdmhondaparts.com is made by place racing. you could also order it from them directly.
well i already modified mine to work but the one i have is hella long and i want to shorten it up so there isnt as much play and for asthetic reasons you know
buy the cable bracket.its the easiest and right way to do it.
i used an acura throttle cable
17910-SK7-A03
that is the acura part number, it fits fucking mint, no problems and it is a good length, if u want it to look stock, that is what i recommend.
it cost me like 35 bucks.
:werd:
