throttle position sensor
mattus72
Member
Hi I have a b16 that is throwing a code for the throttle position sensor. I know you cant buy the sensor through honda or at any autopart store. so my question is does anyone know if those sold on ebay claiming to be for honda really work? or does anyone have a throttle body which I believe is a 60mm for sale? -thanks Matt
You can get another tps sensor off of another throttle body. Grind the rivets off with a dremel tool. The holes are threaded on the inside of the throttle body. Then use some bolts that screw into those holes to mount the tps sensor.;)
