throwing code 20
APEXi
hey guys im throwing code 20 on my b18 eg, im using a jdm p72 ecu.... how do i clear the code? is it doing any damage?
thanx
20 Electronic load detector - possible open or grounded circuit in ECU wiring
to clear a code, disconnect the battery, turn on the lights (to discharge remaining current quickly) and reconnect the battery. If you get the code agian I would say something is up. What it could be I don't know.
Thanx for the reply, i'll give it ago 2moro morning and see if it sorts out the problem.
any 1 else have any ideas how to get this sorted??
